Modify pages in multipages tiff files
Jean Marie
Post by Jean Marie »
I have scanned documents in a multipages tiff file but I want to adjust the brightness and contrast before printing then in PDF.
If I modify the first page :
- it does not modify the other pages,
- if I save the tiff file, I save only the modified page,
- if I move to the next page I loose the modification of the first page.
Is there a way to modify all the pages at the same time ?
(I then do not even need to save the file as I just need to print it in PDF)
JM
eL_PuSHeR
Re: Modify pages in multipages tiff files
Post by eL_PuSHeR »
Extract all pages to a folder. Do any batch processing you need and then create a new PDF file.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
