I'm new to this forum.
I've spent all afternoon trying to convert my Konica Picture Show pix from 2001. XnView says it supports KQP format but I can't get it to work.
Any suggestions?
KQP conversion to JPG
Re: KQP conversion to JPG
• Konica Camera File *.kqp is supported at reading only, thus you can't convert such images into any other format…
jonezee54
Re: KQP coversion to JPG
Thanks for the quick reply, Claude.
I'm disappointed to learn this.
Does this mean all those thousands of images belonging to Konica PC Photoshow are trapped forever?
PHIL
PHIL
Drahken
Supposedly "thumbsplus" works with KQP files. It's commercial, but there's probably a trial version you could use long enough to convert your pics to a normal format.
I've never heard of this format before, but it appears to be a slideshow/animated kind of format? Have you tried to extract frames?
Also, if xnview will open the pics at all, you could make new pics from screencaps of the KQP ones. It would be somewhat labor intensive & the results wouldn't be perfect, but it'd be better than nothing.
- Forum Librarian
jonezee54, what happens if you change your settings to this:
- Tools » Options... » General » Operations » Display all image file types = activated
Tools » Options... » Browser » File List » Misc » Recognize only by extension = disabled
- Forum Librarian
PC PictureShow was a program developed by Pegasus Imaging (now Accusoft Pegasus) for Konica (later Konica Minolta).
The software was available as a free download, enabling users to view and convert images encoded in the proprietary KQP (Konica Quality Print) file format.
Konica Minolta Camera & Photo Support ([url=http://ca.konicaminolta.com/]Notification of the Camera, Photographic and Processing Products[/url]) wrote:Konica Minolta Photo Imaging, Inc. ceased its Camera Business Operation as of 31 March, 2006, and since 1 April, 2006 Sony Corporation has been providing customer service for Konica's, Minolta's, and Konica Minolta's cameras (excluding Film-in cameras) and camera-related products except for the binoculars.
Sony eSupport ([url=http://esupport.sony.com/perl/news-item.pl?news_id=120]Notice of Service Closure for Konica Minolta Products[/url]) wrote:Sony has been providing customer service for Konica Minolta cameras and related products since April 1, 2006.
As of January 1, 2011, Sony will no longer provide customer service for Konica Minolta products.
- Konica
- PC PictureShow Products
PC PictureShow is a picture viewing utility that displays your pictures all at once in the Picture Index, or in an automatic PC PictureShow one after another. Pictures can have comments or notes added to each picture or be rotated for viewing in the correct orientation. PC PictureShow also allows you to convert and export the pictures into standard bitmap (BMP) or pict (PIC) image formats for use in other programs such as word processors, paintbrush, or image enhancement software, or into JFIF image format for transmission over online services such as the Internet. You can advance through the pictures forwards and backwards, add text notes, and copy pictures to the clipboard. Pictures can also be removed from PC PictureShow or zoomed to fill the screen.- Software Download
- PC PictureShow for DOS/Windows v1.3 (ZIP format)
- PC PictureShow for DOS/Windows v1.3 (ZIP format, incl. program files + demo pictures)
- PC PictureShow for DOS/Windows v1.3 (self-installing)
- PC PictureShow for DOS/Windows v1.3 (self-installing, incl. program files + demo pictures)
- PC PictureShow for Windows v3.06 (ZIP format)
- PC PictureShow for Windows v3.06 (self-installing)
- pcps306s.zip
- Software Download
- Konica Minolta Photo Imaging
- PC PictureShow
The most significant update in years, Version 4 adds a number of new options including support for BMP and TIF files, Index Print, and email capabilities, some of our customers' most requested features.- Driver & Software Downloads » PC PictureShow
- PC PictureShow v3.7 for Windows (self-installing)
- PC PictureShow v4.0 Help
- PC PictureShow v4 for Windows (self-installing)
- PC PictureShow Product Page
PC PictureShow is a simple picture viewing and editing utility. Designed to work with Konica Minolta PC PictureShow CD and diskette, it will display all of the JPEG, BMP, TIF, PIC, and KQP images in the selected folder. The images can be viewed and printed as an index, individually, or as a slideshow.
- PC PictureShow
- comp.graphics.misc: Konica PictureShow graphics format
- rec.photo.digital: Converting Konica Picture Show images to JPEG images
Drahken
This is why propietary image formats suck. They should be avoided whenever possible, and if you can't avoid them completely (like if you have a cheapass camera that forces you to use it) they should be converted to a normal format at the first possible opportunity (ie, as soon as you offload them to your comp, use their software & convert it to any conventional format). Then make sure to archive the good copies & throw away the propietary crap.
