[Solved]RC5: Outline text wrong on many fonts
Locked
marsh
Post by marsh »
When white outline is selected, green text selected, the resulting text is often invisible, all one color, or just weird, depending on the font chosen.
courier new .......... all white
8514 oem ......... invisible (nothing appears)
courier ......... invisible
fixedsys .......... invisible
arial ........... working
arial black ........... working
comic sans ms ........... working
georgia ........... working
impact ........... working
lucinda console .......... all white
lucinda sans unicode ........... working
microsoft sans serif ........... working
martlett ...........some white, some green.
modern ........... incomplete corrupt outline
ms sans serif ............ invisible
ms serif ........... invisible
palatino linotype .............. weird
Roman .................... weird incomplete outline
Script ...................... weird, incomplete
Small fonts ............... invisible
Symbol ................... weird
system .................... invisible
Tahoma .................. weird
terminal .................. invisible
Times New Roman ......weird
Trebuchet ................... ooks all green, no outline.
Verdana ..................... looks all green, no outline.
Re: RC5: Outline text wrong on many fonts
marsh wrote:When white outline is selected, green text selected, the resulting text is often invisible, all one color, or just weird, depending on the font chosen.
Yes, outline can not be used with some fonts...
Locked
