when making some modifications of images (Ctrl+U), you can select "delete original". When performing action, XnMP warns you of your choice (and this is great compare to XNV) but it you chose not to change the name, XnMP asks you for each file if you want to replace the original file by the new one. If I chose "delete the original" it is obvious I do not want to keep the original
Image modifications and delete original
lian
What a dumb program
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
