Visual Image-converter and Script-editor
UKoenig
Post by UKoenig »
I finished the new Image-converter and Script-Editor
Let me know, if still something missing !
Many things are still possible like extracting Frames of a Multiple TIF or adding Frames,
Noise-reduction ...
Also a nice Solution for NON-Fwh-users !!!
Download ( 4.2 MB )
http://www.pflegeplus.com/fw_downloads/convert1.zip
All new ( converted ) Images are saved like : Olga.jpg => _Olga.tif
Any new Style-selections will use the Original, You don't need to reload the Original by yourself.
There is a Button < Reload > that will force to display the Original.
The Button < Script > shows the needed Script after a converted Image.
From Command-line, You can call CONVERT.exe like < Convert .\images\olga.jpg 3 >
Convert will load Olga.jpg from subdir \images and displayes the Ribbonbar-Page Number 3 ( Watermark )
Load a Image :
( displayes the Name and full name with path )
Sharpen a Image with a selected factor :
Select a Contrast-factor for the Image :
Define the Lens-radius for the Image :
Watermarks on defined Position or predefined.
With TSelex-position 1 = ???, You can click on the Background-Image for the Watermark Top / Left-position.
All other Selections are predefined :
top-left, top-center, top-right, center-left, center, center-right, bottom-left, bottom-center, bottom-right
Resize Image to defined Size : Width, Height or Percent :
( defined Horizontal ignores Vertical and defined Vertical ignores Horizontal )
Rotate or Flip a Image :
Convert a selected Image to a new Format
All Selections are creating a SCRIPT, You can add to Your Application.
( PDF is included. Some more needed ? )
Crop a Image of a defined Area or Click on < Image TOP-left and BOTTOM-right > :
Justify the brightness of a Image :
Best Regards
Uwe :lol:
