XNViewMP0.37.8 Small details or disadvantages
Vapavite123
Post by Vapavite123 »
Translation (Google) :?
Full Screen
Loss shortcuts "i" and F11 during a change of "record" if the full screen is active!
You have to click (1x) in full screen or close it to find shortcuts.
Hide scrollbars
Little confusion in the recording of the parameter. We must close the program and the setting is taken into account in the full screen, which is not the case for the view mode (Image) and reacts directly after closing the settings window!
Layout option (Backup / Restore)
You have to click 3 times to restore the saved layout!
If save, 3 Menu Layout / View and Full Screen>> Clic1x in layout and 2x Zoom (left corner of the window)
Picture Mode> Tool "Defined Grids"
In the configuration window there are three call buttons ......... Usefulness of these buttons because they are not active?
Assumption:
"Pre-defined grids" that should appear inside the preview window below it!
Recorded three possibilities (unchangeable) or fail a record button to choose a pre-établire!
Suggestion:
Automatically linked to the button the window "Grid" (One button with arrow). Occupy less space in the toolbar as useful if use of the grid according to the processed images (definition, clarity, color, zoom)
Header (Thumbnail and Batch Conversion)
There are changes of words by showing the arrows up / down. Is it possible to limit duplication!
This may be necessary to save space!
Edit pane IPTC / XMP
Pane "Request" which appeared with the scrolling thumbnails. Deleted?
Settings window
Explorer> Tab "Quick Find"
- Lack of "Search in XMP fields!"
File> List Tab file:
- Show the file is checked and grayed companions (or parameter problem with it!)
Fr : :mrgreen: Petits détails ou inconvénients
Plein écran
Perte des raccourcis " i " et F11 lors d'un changement de "dossier" si le plein écran est actif !
Il faut soit cliquer (1x) dans le plein écran ou le fermer pour retrouver les raccourcis.
Hide scrollbars
Petit confusion du à l'enregistrement du paramètre. Il faut fermer le programme pour que le paramètre soit pris en compte dans le Plein écran, ce qui n'est pas le cas pour le mode Vue (Image) qui réagit directement après le fermeture de la fenêtre des paramètres !
Option Disposition (Sauvegarde/Restauration)
Il faut cliquer à 3 reprises pour restaurer la disposition sauvegardée !
Si sauvegarder, Disposition 3 dans Menu/Vue et en Plein écran >> Clic 1x dans disposition et 2x sur Agrandir (coin gauche de la fenêtre)
Mode Image > Outil "Defined Grids"
Dans la fenêtre de paramètrage il y à trois boutons d'appel.........Utilité de ces boutons car non actfs ?
Supposition :
"Grilles pré-définies" qui devraient apparaîtrent dans la fenêtre de prévisualisation située en-dessous !
Trois possibilités enregistrées (inchangeable) ou manquerait un bouton d'enregistrement de choix a pré-établir !
Suggestion :
Lié automatiquement cette fenêtre au bouton "Grille" (Un seul bouton avec petite flèche). Occuperait moins de place dans la Barre d'outils car utile si utilisation de la grille en fonction des images traitées (définition, clarté, teinte, zoom)
En-tête (Vignette ou Convertion par lot)
Il y a modification des mots en faisant apparaître le flèchage ascendant/descendant. Peut-on limiter le chevauchement !
Ceci est peut être nécessaire pour gagner de la place !
Fenêtre Editer IPTC/XMP
La sous-fenêtre "Demander" qui apparaîssait avec le défilement des vignettes. Supprimée ?
Fenêtre des Paramètres
Explorateur > Onglet "Recherche rapide" :
- Manque "Rechercher dans les champs XMP" !
Fichier > Onglet Liste fichiers :
- Montrer les fichiers compagnons reste coché et grisé (problème de paramétrage ou devenu inutile !)
JohnFredC
Re: XNViewMP0.37.8 Small details or disadvantages
Post by JohnFredC »
Vis-a-vis the Defined Grids dialog:
It is simply not yet finished. Pierre has been kind to take into consideration my original rather ambitious idea for the grid option (here), a non-trivial task, due to the many options.
I too hope he finishes it soon, though. :D
John
Vapavite123
Hello, johnFredC,
Thank you for your response and thank you to Peter for responding to your request.
Knowing now that it's being built, I would suggest that the two options, grid and pre-defined grids are linked by the same button in the toolbar (Spinner)! Button = click on Appearance of a grid directly in the image. Arrow = is the definition window or down or is listed pre-established grids and the ability to access the definition window.
I hope this application does not add too much difficulty in this project.
Yours
Hello, JohnFredC,
Merci pour votre réponse et merci à Pierre pour avoir répondu à votre demande.
Sachant maintenant que c'est en cours de construction, je proposerais que les deux options, Grille et Grilles pré-définies soient liés par le même bouton dans la Barre d'outils (Bouton fléché) ! Clic sur bouton = Apparition directe d'une grille dans l'image. Flèche = soit la fenêtre de définition ou un déroulant ou serait énuméré les grilles pré-établies et la possibilité d'accéder à la fenêtre de définition.
J'espère que cette demande n'ajoute pas trop de difficulté à la réalisation de ce projet.
Bien à vous.
