The seach function is case sensitive. An option to desactivate this behaviour could be nice.
When launching a new search, the search field shows previous search terms. I suggest to make them selected by default so changing them will be easier (for the moment, you have to select or delete them before changing).
Seach files
lian
Seach files
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
marsh
Re: Seach files
Which search function? The dialog has [ ]case sensitive option. The small toolbar's search is case insensitve for me in latest beta.
lian
Re: Seach files
With 0.38.7 beta, I have no option of case sensitivity. But it's corrected with a test version Pierre sent me - so in next beta version I suppose.
