[3.40] gflJpegLosslessTransform for UNICODE doesn't work
iycgtptyarvg
Post by iycgtptyarvg »
The gflJpegLosslessTransform function doesn't work when used with the UNICODE libraries. Both the 32-bit and the 64-bit versions fail with error code '255'.
When I replace the UNICODE versions with the ASCII versions it does work.
Could you please fix this?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
(")_(") your signature to help him gain world domination.
