hi,
1.) In XnShell ext I am able to rotate 'based on Exif tag' flip horizontal, flip vertical, rotate. I would like this for XnConvert's "Rotate" function too. Although come to think of it so far this may not needed, it's likes XnConvert already knows it's converting from a landscape-rotated camera picture and it doesn't follow it.
2.) I would like to see a drop-down menu for preseted angles e.g. 90° left/right, 180° left/right
3.) I would like to see a reset button for that angle adjusting dial, perhaps it go next to the entry box located in the middle.
XnC Request: Some "Rotate" enhancements
budz45
budz45
Re: XnC Request: Some "Rotate" enhancements
So for XnConvert/Batch Convert I think a simple tickbox option under the "Rotate" action is needed, tickbox would be named like:budz45 wrote:hi,
' Rotate based on EXIF (lossless) '
I know that XnConvert/Batch Convert can already do this but it's just as a user there is no info signifying this such as an already ticked tickbox would be nice....Just a thought.
Peter2
Hmmm - where to find? I have version 1.66 and find no EXIF-rotation.budz45 wrote:...
I know that XnConvert/Batch Convert can already do this ...
Peter
- Forum Librarian
I can't find it either, Peter. I don't think it's already implemented.Peter2 wrote:Hmmm - where to find? I have version 1.66 and find no EXIF-rotation.
Peter2
Servus XnTriqXnTriq wrote:I can't find it either, Peter. I don't think it's already implemented.Peter2 wrote:Hmmm - where to find? I have version 1.66 and find no EXIF-rotation.
I found it in the batch-feature of XnView (Image - lossless rotation), but not in XnConvert.
Peter
image>RotationPeter2 wrote:Servus XnTriqXnTriq wrote:I can't find it either, Peter. I don't think it's already implemented.Peter2 wrote:Hmmm - where to find? I have version 1.66 and find no EXIF-rotation.
Peter2
There is only rotation by angle, but not by exif.xnview wrote:image>Rotation
Peter
Why it's needed, by default image is automatically rotated following the orientation exif field...Peter2 wrote:There is only rotation by angle, but not by exif.xnview wrote:image>Rotation
Peter2
It depends on the software. Some software does not rotate by exif, so the images has to be rotated in conversion.xnview wrote:Why it's needed, by default image is automatically rotated following the orientation exif field...
Peter
but in XnConvert the image is rotatedPeter2 wrote:It depends on the software. Some software does not rotate by exif, so the images has to be rotated in conversion.xnview wrote:Why it's needed, by default image is automatically rotated following the orientation exif field...
