hi,
The "Close other tabs" right-click feature is no longer causing a program crash starting from MP 0.38.8 build. That is Excellent.
However,
If I open more 3 or more picture's from the Browser, to open in each Viewer tabs and then I perform a "Close other tabs" on the last opened tab, then only that last opened tab get's closed out of the group of tabs that are still open.
easy reproduction;
1.) download & extract v0.38.8
2.) Create an 'xnview.ini' in the same extracted program folder
3.) Open 3 image files (individually) from the Browser, for to open in each Viewer tab
4.) Go to the last opened viewer tab and do a "Close other tabs" on that last tab
4.) Evidently notice how only the last tab get's closed
5.) Same thing happens for any more than 3 viewer tabs. E.g. 4,5,6 etc
Note: If I open 4 viewer tabs, then the "Close other tabs" action only works properly on the 1st or 2nd tab out of the 4 opened (not the 3rd or 4th).
btw, Also should the "Close other tabs" also close an opened Browser tab too? Or should the Browser tab continue to remain exempt from this tab closing behavior?
0.38.8 Win: Misbehavior with 'close other tabs' feature
budz45
budz45
Re: 0.38.8 Win: Misbehavior with 'close other tabs' feature
Fixed in MP 0.38.9
