v.0.38.9 Search titles duplicated
marsh
Post by marsh »
Currently, we have a search dialog and a search field in browser.
The problem is both are called by same name. If the one in small toolbar were labeled "Quick Search", it might be easier to discuss?
Or "find", "locate".
Re: v.0.38.9 Search titles duplicated
you means the greyed text in the edit box to change?
marsh
Post by marsh »
xnview wrote:you means the greyed text in the edit box to change?
Yes, I think we are referencing the same one (default text part of small toolbar).
Vapavite123
Post by Vapavite123 »
Another idea "Find File"
Fr :Une autre idée "Chercher fichier"
