Does XnView have a feature that can label batch files in alphabetical order? I sometimes have pictures that end with Scene 1 for example.
Instead of it ending with Scene 1 1, Scene 1 2, Scene 1 3, can it batch rename using Scene 1a, Scene 1b, Scene 1c etc?
Batch Rename in Alphabetical Order
Re: Batch Rename in Alphabetical Order
Do you have tried 'batch rename'?
Brans
Yes I'm using batch rename in XnView, but I don't know how to rename the pictures in alphabetical order as I described earlier.
you have 'duplicate', here you can change with characters instead of numbers
