Some of the documentation for the ActiveX version is not updated with the latest correct info on all of the features of the ActiveX version.
In the actual GFL SDK ActiveX component, the "raw" format outputs a 256 level grayscale image REGARDLESS of what the actual bit depth and color palette is set at (via the "ChangeColorDepth" command). This bug needs to be fixed.
When will GFL SDK ActiveX be updated (and bugs fixed)?
Ben321
