Problem when deleting Thumbs.db
tony_onsitu
Post by tony_onsitu »
XnView generate a lot à thumbs.db files.
On our network, there is a problem with permissions with these files. Noboy can't delete the thumbs.db even if you're the "big adminstrator"... it's not very useful
Have you got an idea to avoid this ?
Thanks in advance
ckv
Re: Problem when deleting Thumbs.db
Post by ckv »
Thumbs.db files are created by Windows explorer, not by XnView. XnView stores its thumbnails in the XnView.db file.
