file list with different details
meinmalli
Post by meinmalli »
I want to have a file list I can export to excel containing the filename and the printed size (in cm).
The function "file list" would be perfect for that task, but there are only predefined values to choose from.
Is there any way to print out filename and printed size of a list of files?
bg
Re: file list with different details
no, but with XnViewMP you can do that
meinmalli
Post by meinmalli »
thanks, I tried XnViewMP, but can't find the function "file list".
Also tried to copy the information from "Details view" but can only copy the filename with path.
How does it work?
Tools/File list
meinmalli
Post by meinmalli »
in the old version I can find "file list" in menue "create".
But in the MP version I have no "file list", neither under "tools" nor under "create".
I uploaded a screenshot of my tools menue. using latest version 0.35beta.
JohnFredC
Post by JohnFredC »
Try here for a later Windows version of MP. Current MP Windows version is 0.38.10
You'll need to sort by Last Modified (click twice) to find it.
File listing is in the Create menu.
John
meinmalli
Post by meinmalli »
wow, thanks! That worked for me!
