Browser crashing in 1.98.2
ShinzuiUindo
Post by ShinzuiUindo »
If I try to open a folder with many files in it. Says the software stopped working.There is one folder I'm using all the time and it usually has 100+ files in it. I am using Windows 7 SP1
Re: Browser crashing in 1.98.2
Only picture files?
ShinzuiUindo
After some testing by removing files I saw that MKV files cause the crash. Though XnView can open MKV files.
DOS386
Post by DOS386 »
ShinzuiUindo wrote:After some testing by removing files I saw that MKV files cause the crash. Though XnView can open MKV files.
MKV format support isn't native, so it's a problem of an external codec.
Meraviglioso
Post by Meraviglioso »
is the problem only with .mkv files or other video formats?
Victorian
Browser crashing in 1.98.5
Post by Victorian »
Browser crashing in xnView 1.98.5
Сигнатура проблемы:
Имя события проблемы: APPCRASH
Имя приложения: xnview.exe
Версия приложения: 1.98.0.0
Отметка времени приложения: 4ec61fbf
Имя модуля с ошибкой: xnview.exe
Версия модуля с ошибкой: 1.98.0.0
Отметка времени модуля с ошибкой: 4ec61fbf
Код исключения: c0000005
Смещение исключения: 000ce34a
Версия ОС: 6.1.7601.2.1.0.256.1
Код языка: 1049
Дополнительные сведения 1: 6bcd
Дополнительные сведения 2: 6bcde7812013385e3f8c6e4751551664
Дополнительные сведения 3: 71ca
Дополнительные сведения 4: 71cababb2ec203f4690473576efaed2e
Re: Browser crashing in 1.98.5
Victorian wrote:Browser crashing in xnView 1.98.5
How do you crash it?
