for a specific picture I can't add IPTC data. XNView pops up a message box "Fehler beim Speichern der Datei" (error saving file). It is a jpeg file, which comes out of my camera, a Pentax *ist DS. Other files from the same photo session can be edited without problems. The problem occurs with XNView versions 1.98.1 and 1.98.2 under Windows 7 64 bit. On another PC with Windows XP and XNView version 1.97.6, I can add and change IPTC data for this file. Copied back to the first PC I can see the newly added data, but when trying to save any changes, the above error message pops up again. By the way in the folder a temporary file of 12 bytes length and with a PNG header remains.
If needed for bug fixing I can provide you this file.
Error writing IPTC data to a specific picture (version 1.98)
Ishibo San
Re: Error writing IPTC data to a specific picture (version 1
Could you send me a sample?
