RC5: Thumbnail Label: Adding & moving entries
Locked
In options, category "Browser > Thumbnail Label", the user can add items. When adding an item, the selection of the item is lost. It would be good if the selection remained on the moved item, this would allow for adding and immediately moving it to another position using the arrow buttons, if needed.
Note:
Since the Thumbnail Labels are not change that often, this is a minor issue.
Re: RC5: Thumbnail Label: Adding & moving entries
helmut wrote:In options, category "Browser > Thumbnail Label", the user can add items. When adding an item, the selection of the item is lost. It would be good if the selection remained on the moved item, this would allow for adding and immediately moving it to another position using the arrow buttons, if needed.
Note:
Fix
In RC6 it's better, but not fully fixed:
When adding an item and then another one, multiple entries are selected on the right side. Instead, only one item should be selected, only..
Verified fixed in RC7. Closed.
Locked
