Where are Shortcut settings (Hotkeys) save to?
budz45
Post by budz45 »
I have recently downloaded & extracted MP 0.39 and then copied my .ini file from my 0.38.10 program folder to use it in 0.39.
All settings, custom window sizes, recent files entries etc remain the same all but except custom hotkey settings better known in MP as "shortcuts"
where are these saved to?
EDIT:- Also where the toolbar saved to, too?
Re: Where are Shortcut settings (Hotkeys) save to?
All is saved with .ini & .db
budz45
Post by budz45 »
xnview wrote:All is saved with .ini & .db
What .db for the shortcuts (hotkeys)?
and
What .db for custom toolbar?
What about the default.keys file and the XnView.db file
Ok, it's default.bar and default.keys
