i use it to watermark pics, different scripts/colors etc, and doing from fullscreen is the best way vs thumbs which aren't always big enough.
ctrl - u
Dreamer
Re: ctrl - u
If you mean Ctrl+U shortcut, then you can change/set it using HotkeyP, more here.
Dreamer
obelisk
Re: ctrl - u
hmm that looks a bit complicated for me.
but in any case in fullscreen mode the command isn't available at all, so you can't set a new shortcut to it
Dreamer
Re: ctrl - u
It's not so complicated, just use spy.exe from HotkeyP menu, perform action you need in xnview view mode (e.g. select menu > image > add watermark) and copy the command, process and window class to "hot key" window in HotkeyP - just select the line, then the buttons above.
For "add watermark" it's:
Hot key (custom): Ctrl+U
Command: Command to active window
Parameters: 338 xnview.exe XmainClass
Make sure you're in the "view mode" fulsscreen, not the browser fullscreen, go to view mode and press F11.
Dreamer
obelisk
Re: ctrl - u
Thanks for that, didn't think you can do commands when fullscreen mode doesn't support that command!
obelisk
Re: ctrl - u
hi
strangely fullscreen is fine
but in viewer mode the dialog comes out w/o the filename added
