Ιs possible batch numbering over my pictures?
Big tree
Post by Big tree »
like this:
How do I get on the images progressively numbered (1,2,3,4...35,36,37 .... )
thank you
ckv
Re: Ιs possible batch numbering over my pictures?
Post by ckv »
There's no easy way to do this, but you can achieve this by first batch renaming all the files with progressive numbers (Use '#' as template in batch rename tool) and then use the batch processing tool to add the file name in the image (Use 'Add text' with '<Filename>' parameter). It's not perfect, but it's better than nothing.
If you want to try this, I would recommend using XnViewMP because its Add text tool has more features.
Big tree
Post by Big tree »
What I do :wink: . But I thought is there an easier way :?: And faster :D
