Hi, I have found a couple of problems:
- Crash when changing between directorys while the thumbnail creation is not finished:
1. Open XnViewMP
2. Change between directories with large images fast
3. Crash
- XnView MP uses much more memory than XnView classic. Is this due to the OpenGL acceleration or QT?
Random crashes
Re: Random crashes
on Windows? x32? How many pictures do you have?BloodySword wrote: - Crash when changing between directorys while the thumbnail creation is not finished:
1. Open XnViewMP
3. Crash
BloodySword
Re: Random crashes
I'm running XnViewMP on Windows 7 x64 (and using x64 build of XnViewMP) with 6GB ram.
The number of pictures is depending on the folder. some have more than 100, some only a hand full.
The pictures are often bigger than 8 megapixels and PNG.
It feels like that when the building of the thumbnails (or reading them out of the database), I klick fast to another directory on the tree, XnViewMP crashes because the process was not completed.
Re: Random crashes
could you send me a big PNG to test?
BloodySword
Re: Random crashes
http://www14.zippyshare.com/v/42112906/file.html
Here it is. Password is xnview.
This picture was prinded as wall paper and is illuminated by 5500 K LEDs. It looks just fine!
Painted by my girlfriend in SAI.
Re: Random crashes
I can't reproduce, you have this crash every time?
Which difference do you have?- XnView MP uses much more memory than XnView classic. Is this due to the OpenGL acceleration or QT?
