Zoom lock doesn't work at all....
rfrank
Post by rfrank »
Hello to everyone....
I tried XNviewMP a few days ago and i just love it, but found 3 issues that concerns me.
1.- Even if i enable the "Enter key" bahavior so i can switch between (Browser/Viewer) when im about to close an image, i can't go back to the browser (pressing ESC works normally)
2.- In viewer mode i can't scroll the image with the keyboard, i need to use the mouse always (bug or intended use?)
3.-Finally... Zoom Lock doesnt work at all.... it always resets the zoom ratio once you change the image.
Anyway, thank you for your time
:mrgreen:
P.D. im using windows XP
Re: Zoom lock doesn't work at all....
rfrank wrote: 1.- Even if i enable the "Enter key" bahavior so i can switch between (Browser/Viewer) when im about to close an image, i can't go back to the browser (pressing ESC works normally)
I can't confirm. ENTER works to switch between viewer&browser for me
You would like to use arrows?
Ok, i'll check
rfrank
Post by rfrank »
1.- Even if i enable the "Enter key" behavior so i can switch between (Browser/Viewer) when im about to close an image, i can't go back to the browser (pressing ESC works normally)
[/quote]
Thank you for your answers Pierre!!!
About
1.- I still have this issue... if im in viewer mode and want to go into the browser, when i press enter i go out, but quickly go into the viewer mode again (think of it as a "fake double enter")
2.- Yes, please it is more comfortable to be able to use the arrows as well if needed
3.- Thank you again!!!... it is weird that the zoom lock doesnt works
:D
Please check XnViewMP 0.48
