Hi, I just discovered XnView and It it what I was looking for in image viewer, but I have problem with Archive Plugin. Every time i double-click on .zip file XnView crashes. I downloaded plugins from here:
http://www.xnview.com/en/addons.html
I unzipped it and moved the .dll files to \xnview\plugins folder (I couldn't find 'addons' folder as was written in website above so to be sure I even created it and moved files there). After that restarted XnView and tried to open .zip - and *crash*. Does anybody know or suspect why it crashes? I have Vista 32bit, SP2 and later updates, laptop. There are two archive plugins and I tested them both (together and separately). It's the only thing that's missing for me in this so I would be glad if someone could help me.
Archive Plugin crash - need help
- Forum Librarian
Re: Archive Plugin crash - need help
Extract contents of archive.zip (Allows to view content of zip, rar, 7z and SQX archive) to:Skraaj wrote:I unzipped it and moved the .dll files to \xnview\plugins folder (I couldn't find 'addons' folder as was written in website above so to be sure I even created it and moved files there).
- \XnView\AddOn\7z.dll
\XnView\AddOn\sqx20.dll
\XnView\AddOn\UNACEV2.DLL
\XnView\AddOn\unrar.dll
\XnView\AddOn\Unzip32.dll
- \XnView\AddOn\Zip32.dll
\XnView\AddOn\ZIPPack.lng
\XnView\AddOn\ZIPPack.xnp
Skraaj
Works like a charm. Used plural 'addons' instead of 'addon'. My bad, thanks for help.
BurnOmania
Have the same issue, even worse!!
Your method dosn't help me too much. already done what you've suggested, XnView is still crashing when am trying to browse folder that contains JPG and ZIP files.
For ex. I have one folder that contains several types of files including JPG, ZIP, TXT...
I can open the JPG file, but when am trying to browse to the next file using the mouse, XnView is crashing.
Problem signature:
Problem Event Name: APPCRASH
Application Name: xnview.exe
Application Version: 1.98.0.0
Application Timestamp: 4e259822
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.17514
Fault Module Timestamp: 4ce7b96e
Exception Code: c0000005
Exception Offset: 00052d37
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1037
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Windows 7 x86 + SP1
XnView 1.98.2
Problem signature:
Locale ID: 1037
Windows 7 x86 + SP1
XnView 1.98.2
If you don't have Addon/Unzip32.dll, do you have always the problem?
BurnOmania
oooopppppssssssss!!!! sorry Pierre. It actually crash only with 001 file type, NOT ZIP archives.xnview wrote:If you don't have Addon/Unzip32.dll, do you have always the problem?
I was been mistaken since both have the same Icon file type.
Any way to disable XnView from detecting this kind of files to avoid the crash??
001 is currently registered to 7-Zip by default.
Could you send me the .001 file?BurnOmania wrote:oooopppppssssssss!!!! sorry Pierre. It actually crash only with 001 file type, NOT ZIP archives.xnview wrote:If you don't have Addon/Unzip32.dll, do you have always the problem?
BurnOmania
I don't think its possible for me sending you all the files. the main 001 and rest of the archives are about 45MB each. (app. 2.5GB)
The archive contains 1 big ISO file.
my question is, why XnView recognized 001 and how can I disable it from the browser? I dont need XV messing around with this kind of files, thats why I installed 7-Zip from the beginning
001 can be a picture format...
