Hi
I can always reproduce a bug : with XnviewMP if i move ALL image from a directory to another one XnviewMP do it bug crash after
No much information on the terminal output :
## MyView::onLoaded ok
MyView::change /home/roumano/Images/2011 09 11 - /IMG_6602_CR2.jpg
###### LOAD BITMAP </home/roumano/Images/2011 09 11 - /IMG_6602_CR2.jpg>
## MyView::onLoaded </home/roumano/Images/2011 09 11 - /IMG_6602_CR2.jpg> </home/roumano/Images/2011 09 11 - /IMG_6602_CR2.jpg> </home/roumano/Images/2011 09 11 - /IMG_6602_CR2.jpg> (0)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by bug-buddy)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libebook-1.2.so.10)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libsoup-2.4.so.1)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libz.so.1: no version information available (required by /usr/lib64/libgio-2.0.so.0)
bug-buddy: /home/roumano/bin/XnViewMP-039/lib/libxml2.so.2: no version information available (required by /usr/lib64/libedataserver-1.2.so.14)
>> Need more information
MP 0.39 (linux x64) crash on move
Re: MP 0.39 (linux x64) crash on move
How do you move files? Drag&drop? Move to?
Roumano
"move to",
Select All file, then right click "move to", choose a directory then xnviewMp will crash.
"move to",
Roumano
Hi, A detail of the bug found today :
If i select all image then right click on the first image then right click "move to", choose a directory then xnviewMp will crash.
if i select all image then right click on the another image (not the first) then right click "move to", xnviewmp will not crash!
Please check XnViewMP 0.48
