Would it be possible for an option to enable/disable scrollbars in the viewer and fullscreen separately? I liked how XnView 1.97 had scrollbars in viewer but not in fullscreen.
P.S. Is there a way to disable the right-click quick zoom in viewer? I'm trying to access the context menu but the image zooms in and out in a flash, which can become increasingly annoying.
P.P.S. In case this was not realized, the checkmark in the "Auto image size" context menu does not change.
Separate Scrollbar Option for Viewer and Fullscreen
winguy2003
