Renaming mp4-files?
mesh07
Renaming mp4-files?
Post by mesh07 »
i'm using the newest version (1.98.2), and before 1.98 (and the ones before).
Is it a known issue, that mp4-files can not be renamed within the filelist/F2? How can i solve this problem?
Well everything else works fine for me.
But i'm having some problems with mp4 files.
My System:
Windows 7 Home Premium 64
Phenom II 4x 2,5Ghz
8Gb Ram
120Gb SSD
Re: Renaming mp4-files?
What's happened if you try to rename?
mesh07
Post by mesh07 »
In German "Fehler beim Umbenennen der Datei".
So in English it would be something like "error on renaming the file".
This error only occurs while trying to rename mp4-files.
And there are often problems while watching them - especially when looking through/zapping through the videos. That often leads to crashes of xnview.
The last thing could be a codec problem.
But issues with renaming seems to be a problem with xnview.
