I'm using XnView on an ArchLinux machine running KDE4.7.1
1) I cannot drag & drop anything within the folders tab
2) I cannot drag & drop anything from the left hand pane (containing folders/files etc) to anywhere on the folders tab
3) If I'm running XnView and add folders/files to a folder XnView has already been into the tree in the folders tab doesn't update to reflect this. I've tried F5 going to another folder and then going back but it still doesn't update.
Linux v0.39 - Drag & Drop and Tree Updating
Re: Linux v0.39 - Drag & Drop and Tree Updating
Same Problems here. I am using XnViewMP 0.39 x64 on Win7 x64
This is not a bug but a lack of feature which hasn't been implemented yet.
Here are the topics on this issue:
http://newsgroup.xnview.com/viewtopic.php?f=60&t=19780
http://newsgroup.xnview.com/viewtopic.php?f=60&t=24111
http://newsgroup.xnview.com/viewtopic.php?f=60&t=21552
http://newsgroup.xnview.com/viewtopic.php?f=60&t=19992
..I hope I am not mistaken in my input to this topic in thinking that this issue is the same as the links I've just posted/.
