Re-locate xnview.db ???
Jack-K
Post by Jack-K »
Is there any way to specify that the xnview.db data base file be on a different disk than C?
Re: Re-locate xnview.db ???
yes in option/System integration
Jack-K
Post by Jack-K »
Thanks. However, I couldn't get it to do what I want until I also installed the program itself on the other disk.
ckv
Post by ckv »
:| You can set the database location at: Options > Browser > Thumbnails > Cache, on the bottom, there is a Use folder section where you can set custom path for xnview.db file.
