When trying to slideshow on filtered files, you can't. After clicking on a image, the slideshow will continue to play images in the folder without regards to filtered images.
Can slideshow be enabled via filtered files or selected images? This will definitely be great as people tend to want to slideshow certain pictures sometimes instead of the whole folder. In addition, can it slideshow according to sort order types in the filter whether chronologically, alphabetically, or type (chrono, alphabet (sort), or any of the properties with the subsort?
[request] filtered files - slideshow
Re: [request] filtered files - slideshow
Could you tell me how to reproduce?
harkonen
tag various files in folder
goto view> select filter> by tagged file
run slideshow, slideshow will show all files regardless of view... Also recommend adding a loop around for slideshow.
And you go to fullscreen, and press play?
