We just installed 0.39 beta and we are experiencing some issues. We are linux shop and are currently running CentOS 5.1 x64 bit with kernel 2.6.18-53.el5. All our software is installed centrally on a NAS which is shared out using NFS v3. Even the users' home dirs are saved centrally.
The problems we are facing are as follows:
1. We can create new categories but can't seem to rename the same. Right-clicking on the newly created category and hitting rename does nothing
2. When trying to delete a category, the program crashes cause of a segmentation fault
Thanks in advance!!
Cannot rename and delete new category
Roumano
Re: Cannot rename and delete new category
About the problem 1. : i have the same problem, sometime.
a get arround : close & re-run xnviewmp : you can rename the categorie
Please check XnViewMP 0.48
