Add Associated program - crash
begem0t
Post by begem0t »
The function "Open with" - "Add (Associated) Program" crashes when used from the viewer's right click menu.
The same function is OK when called from the browser.
Also, the menu order is different between browser and viewer, which is confusing.
tested on:
win7 - 64bit / xnView MP 0.39 - 64bit
[xnView - simply the best viewer on this planet]
Re: Add Associated program - crash
begem0t wrote: Also, the menu order is different between browser and viewer, which is confusing.
What is different??
Please check XnViewMP 0.48
