Thanks for the great software. When I delete a folder, the parent folder becomes selected. It would be very helpful for me if there is an option to select the previous or next sibling folder when the current one is deleted.
Keep up the good work.
Select Next or Previous Folder on Deletion
Re: Select Next or Previous Folder on Deletion
I came to this forum, just to agree with this suggestion. I really like XnView and I am using for my personal and work files. I have to deal with thousands of folders and it is very very unprofessional situation when you have to delete folder number 1500 and after that scroll down again looking for folder 1501.
Or maybe I just dont know any other solution, maybe we can change it somewhere in options? Any ideas?
