Pipe character can't be used in information display
Crysler
Post by Crysler »
In "Options > View > Fullscreen > Show Information" you can set the display in fullscreen.
I want to display the fields in a single line with pipes as separator, so I entered
<Filename>    |    <Exposure Time> s    |     f<F-Number>    |    ISO <ISO Value>
This displays correctly right after checking the changes in fullscreen mode, but when you close and reopen Xnews the pipes are replaced by an invisible character (in the configuration textarea) and in fullscreen display the data shows up in separate lines.
Using 1.98.2, Win7x64
Crysler
Re: Pipe character can't be used in information display
Post by Crysler »
Is anyone else seeing this or is this a local problem on my system?
A known issue
Crysler
Post by Crysler »
...now that you said it I searched again and found an old thread from 2006 where something like this is mentioned.
Seems not easy to fix, so I switched to the symbol that was suggested in that thread (Alt+0166) which is ok for me.
