Hi!
When I print something, the interface presents me some default print layout...like 2"x 3" , 3,5" x 5" , 4" x 6" etc....these formats are complety unuseful for my activity...
I would like to set my own format and save it with a name.....how can I do this?
Thanks!
Change default print layout template
Re: Change default print layout template
You means in 'Single - custom'?
thes
Yes...Single - Custom.... when this option is selected there is an other "custom" size below..like the ones I wrote (3,5" x 5" etc...)...I want to modify these size and save them.xnview wrote:You means in 'Single - custom'?
[email protected]
I've got similar problem. I need print same card (clone) 4 times with size 9cm x 6cm. For this reason I need in "Print>Layout>Page Layout>Pictures collections" possibility add custom layout. Is this possible? May be by the ascii edition of some XML configuration files or etc...thes wrote:Yes...Single - Custom.... when this option is selected there is an other "custom" size below..like the ones I wrote (3,5" x 5" etc...)...I want to modify these size and save them.
Sorry but currently not possible[email protected] wrote:I've got similar problem. I need print same card (clone) 4 times with size 9cm x 6cm. For this reason I need in "Print>Layout>Page Layout>Pictures collections" possibility add custom layout. Is this possible? May be by the ascii edition of some XML configuration files or etc...thes wrote:Yes...Single - Custom.... when this option is selected there is an other "custom" size below..like the ones I wrote (3,5" x 5" etc...)...I want to modify these size and save them.
