hello
there is a paradox in 0.39 beta
If you select several pictures, and ask for batch conversion (from the "tools" menu only, not available by right click yet) , you have the same dialog as in 1.98.2, including an "options" button, opening a dialog where you can choose, for instance for jpg format, compression level, keep or not exif data, iptc data, etc... Good !!
But if you open a single picture, if you modify it and select "file/save as" , you get a dialog where you can enter a file name, select a directory, but you can't choose or even know the parameters that will be used...
Save as... with unknown options: no "options" button.
Markorki
Dommage, l'était sympa cette planète ;-(
Re: Save as... with unknown options: no "options" button.
You have File>Format settings
