Long time no see. ;D
If you try to compare different filetypes of the same image, and thus have the same file name, you don't know which one is which without the extension.
For example, i was trying to compare an image stored as JPG and JP2, and since they both had the same name... So please add the file extension to the name in the upper left.
Add extension to image comparison
Danny
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
eL_PuSHeR
Re: Add extension to image comparison
I think this was included in v1.98.2
What version are you using?.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
