Sir,
If I understand correctly XnView, when you export ITPC data, all existing individual ITPC fields are converted to CSV, picture per picture.
The issue is that the CSV ouput records have a variable format with more or less fields, if your pictures have more or less ITPC fields filled or not.
Is there a feature to define a fixed output format, for instance to select only required fields, e.g. Caption, Author, Supplemental Category.
Empty fields would be either filled with a dummy value, say "x", or better there would be two consecutive separators in the CSV file.
Other field values would be just discarded.
The net result being a CSV file that would be read by Excel so that expected values would be present in the right columns
Regards, Philippe
Export ITPC data to CSV format
Re: Export ITPC data to CSV format
Yes, currently you can't choose which IPTC data you want to export
pdussart
Pierre,
is there a plan to allow the selection of some IPTC fields, instead of a variable format ?
Regards, Philippe
Regards, Philippe
