1.98.2 - Batch Rename EXIF Date sort bug
dosdan
Post by dosdan »
XnView 1.98.2en
In Batch Rename when you sort by EXIF Date, the first file is out of sequence.
In the example above K5__4303.PEF (Pentax K-5 raw file) is later then the other files below it. This is my second attempt. I'd already untagged K5_4304.PEF which was the original out-of-sequence file, then it moved to K5__4303.PEF.
Bug does not occur if you use EXIF Date (descending) order, but unfortunately you can't step by -1, so the renumbered files will be in the reverse order
Dan
Re: 1.98.2 - Batch Rename EXIF Date sort bug
I can't reproduce, could you send me 3 files?
dosdan
Post by dosdan »
Pierre, I've noticed something else about this bug: the mis-sorted files change position every time during the Batch Rename session when I reselect EXIF Date from the drop-down list of sort orders:
Initial opening:
1st EXIF Date selection:
2nd EXIF Date selection:
3rd EXIF Date selection:
The three PEF files used in this demo are available here:
http://users.on.net/~dosdan/Sorting%20bug/
Dan
Ok, i can reproduce with RAW files...
