XnConvert for Mac dies when using NAS
absuk
Post by absuk »
Guys,
do you have a link to the older version of xnconvert, version 1.10 does not work at all, it keeps on crashing, completely un-usable. it seems to have an issue when ever you are dragging files from the network drive, otherwise if dragging items from the local machine it works ok.
I have a debug info if anyone wants it.
cheers
Abs
absuk
Re: xnConver for Mac Dies when using NAS
Post by absuk »
Oh, it actually does not work when you drag or open 20 or so photos into this application, I am using Mac Lion. anyideas
You have the problem with more that 20 files??
No problem with previous version?
absuk
Post by absuk »
no, the previous version worked fine, but as soon as i upgraded is screwed it up, in fact i just tried to add 4 images from my local drive and its crashed, what have Xn done in the new version. also, If you want i can attach the debug info.
cheers
Abs
absuk wrote:no, the previous version worked fine, but as soon as i upgraded is screwed it up, in fact i just tried to add 4 images from my local drive and its crashed, what have Xn done in the new version. also, If you want i can attach the debug info.
Which format of picture files do you drag&drop?
absuk
Post by absuk »
Hi, any image format i use crashes, do you have the link to the previous version as that one worked perfectly. here is the link to the crash report from my mac lion.
http://wtrns.fr/jBgpTzGt185BBC0
Strange, i can't reproduce... You have old versions here
http://download.xnview.com/
Tell me which version work?
absuk
Re: XnConvert for Mac dies when using NAS
Post by absuk »
I downloaded V1.02
XnConvert Version 1.02 (May 5 2011) - Libformat version 5.90
this works as it should, but version XnConvert-110-mac.dmg dose not work.. not sure why. on my system, if i drag one image to this version it works ok, but as soon as i drag more it crashes.
anyways. am just gone use 1.02. it works perfectly. cheers for the links
Abs
ThreeDeePixel ltd | FMCG Images
I've tried on Lion, with a shared smb folder, but i can't reproduce the crash :(
