Hi
I use XnView and installed the OpenEXR plugin
Also I use a SageThumbs by Nikolay Raspopov
SageThumbs is a powerful shell extension allowing to preview enormous amount of image formats directly in Windows Explorer by using Pierre-e Gougelet's GFL library (XnView's author).
I want to see in Windows Explorer thumbnails of EXR files
But EXR is not included in the GFL library 3.40 which uses SageThumbs
How can I add EXR to the GFL library?
SageThumbs & EXR
Shah
Re: SageThumbs & EXR
Well so what?
What are your thoughts on this?
You need to copy openEXR.dll in plugins folder of XnViewShellEx
thibaud
if on a hurry, you may want to give Mysticthumbs a try.
(from my experience: awesome utility with extensive file type compatibility & top notch support)
Shah
xnview wrote:You need to copy openEXR.dll in plugins folder of XnViewShellEx
I have downloaded exr.zip from http://www.xnview.com/en/plugins.html
within the archive IlmImf.dll
I copied it to C:\Program Files(x86) \ XnView \ PlugIns
The program XnView displays thumbnails of EXR, but SageThumb does not see them.
openEXR.dll I could not find
Where is my mistake?
Sorry it's IlmImf.dllShah wrote:I have downloaded exr.zip from http://www.xnview.com/en/plugins.html
And XnViewShellEx.dll is in "C:\Program Files(x86) \ XnView"??
Shah
Yes, XnViewShellExT.dll is in this folderSorry it's IlmImf.dll
Ok, right. XnViewShellEx & SageThumbs can't load, i don't understand why...Shah wrote:Yes, XnViewShellExT.dll is in this folderSorry it's IlmImf.dll
Shah
Hello Pierre!
I spoke with Nikolay Raspopov.
EXR should be added to your GFL library.
Add it please !!!!!!!!!!
wenneker
I'm also trying to get exr thumbnails working with sagethumbs. Any news on getting it to work?
planete
Hi There!
thank you Pierre!
we still wat very much for adding open EXR to your library. Because we really need to see EXR thums in xplorer. and we still cant...
Or maybe there is a new method already, that i dont know??
thank you Pierre!
