NConvert for FreeBSD 7.3 x64
sanitch
Post by sanitch »
For my website I need NConvert for FreeBSD 7.3 x64. Versions for FreeBSD 8 and FreeBSD 4.x doesn't seem to do the job for me.
Where can I get NConvert for FreeBSD 7.x x64?
Best regards,
Nikita
Re: NConvert for FreeBSD 7.3 x64
Version for FreeBSD 8 doesn't work on 7.3?
sanitch
Post by sanitch »
No, it doesn't unfortunately. I've tried it but without any success.
Best regards,
Nikita
What's happened??
sanitch
Post by sanitch »
In the log file I see the the following line: "wmftogif: not found"
I'm trying to resize jpeg file and save it.
Best regards,
Nikita
which command do you use?
sanitch
Post by sanitch »
Pierre, everything works fine. There was a problem with my code that prevented it from working.
Now it still gives an error "wmftogif: not found" but does the resize and crop :)
Thank you and sorry for wasting your time.
Best regards,
Nikita
DOS386
Post by DOS386 »
sanitch wrote:still gives an error "wmftogif: not found" but does the resize and crop
apparently it tries to find the plugin: http://newsgroup.xnview.com/viewtopic.php?t=22005
