When I recursively show all images (2000+) from a folder-structure and then use batch convert on some of them, after that is finished, only the current folder is shown.
I would expect that the "show recursively" view would still be active. Especially when you sort so many images, this takes a lot of time, so it becomes very time-consuming to "show recursively > sort" again and again. Would be nice, if this could be improved.
Lars
Batch convert vs. recursive listing
Vapavite123
Re: Batch convert vs. recursive listing
Yes!
Indeed, when is use the recursive mode, a number of operations that return to the parent folder, which is terribly tedious if sub folders contain hundreds of images!
See also post: http://newsgroup.xnview.com/viewtopic.php?f=56&t=24359
"A Copier-Couper/coller XNV Explorer to Windows Explorer or another instance of XNV, etc ....
Salut,
Oui !
En effet, lorsque est utiliser le mode récursif, un certain nombre d'opération fait revenir au dossier parent, ce qui est terriblement fastidieux si les sous dossiers contiennent plusieurs centaines d'images !
Voir aussi poste :http://newsgroup.xnview.com/viewtopic.php?f=56&t=24359
" Un Copier-Couper/coller de l'explorateur XnV vers l'explorateur Windows ou une autre instance de XnV,...etc.
Yes!
Salut,
Oui !
