v0.39 - exif incompatibility
pim
Post by pim »
Hi.
XnView cannot handle pictures with metadata in specific format. I suppose it's bug of XnView because digiKam works with same files without problems. So does Exiftool (it only outputs warning: "[minor] Error reading PreviewImage").
What: When trying to change category of picture, changed value is saved only into db but not into picture metadata and XnView freezes eating 100 % of CPU time. After killing the XnView process and starting again, in db appears second occurence of the same picture. The only difference is path. Original has:"/path/file.suffix", newly created copy has:"//path/file.suffix".
Where: Tested on Arch Linux 64bit, Windows XP
When: Editing any unmodified JPG from Sony A-55 with FW v1.10 (Photos taken with FW v2.00 are OK)
How to reproduce: Open picture -> change (tick or untick) category -> instant freeze
Sample: http://dl.dropbox.com/u/30333870/DSC00868.JPG
CMD output shows nothing special:
## MyView::onLoaded ok
### resetViewport (1b246d0)  ==> 100 30  (45 30) 0 0
SetDate : 2
######### CategoryModel :: checkAndSave()
## NEW CAT CHECKED
  => 30
## CAT REMOVED
LOAD INFO <//media/PHOTOS/2011_04_03/DSC00868.JPG>
By the way why is there sometimes single slash and sometimes two slashes at the beginning of the path?
This screen is from settings:
Version 0.92 x64 (Sep 29 2018) - un*x
Re: v0.39 - exif incompatibility
Please check XnViewMP 0.48
pim
Post by pim »
Well it's a shame I forgot to answer.
Yes, since v0.48 it has started to work. Thank you with one year delay:-).
