While "NConvert" can convert eri format (with plugin), XnC doesn't seem to be able to.
Is this normal?
Unable to convert ERI format
exoticgirl6969
Re: Unable to convert ERI format
Yes, I've copied it over from the XnView folder.xnview wrote:Do you have the plugin in XnConvert?
