slideshow screen off and single instance
riow
Post by riow »
Hi there, I've created many .sld file for elderly usage. However there are two main issue I found and I don't know if XnView has option to solve the issues.
1, Whenever playing back slideshow for photos and video clips, the screen off will be activated after timeout. Could this be deactivated during slideshow?
2, Elderly uses computer has many difficulties in stopping slideshow but keep opening additional slideshows simultaneously. How to set XnView to be single instance for slideshow?
Thanks.
Re: slideshow screen off and single instance
riow wrote:1, Whenever playing back slideshow for photos and video clips, the screen off will be activated after timeout. Could this be deactivated during slideshow?
I desactivate it, so i don't understand why it start :(
Do you have checked 'only one instance'?
riow
Post by riow »
xnview wrote:I desactivate it, so i don't understand why it start :(
I can't deactivate it for the tv recording program which is running behind and for saving the bill of electricity. Is there any command line to deactivate it?
I see. I'll try it now.
