Number of similar files.
notifear
Post by notifear »
Hi, this is my case:
I use to work with folders that normally has repeated files, but when i use the "find similar files" option, i dont know how many files has been found. That's why I think that this option should show how many files that has been found, basically to know if you will spend one hour deleting files.
Thank you and congratulations for this GREAT software.
