I use Win7 64bit
I calibrate my mon.
When I view a jpg, in xnview it doen't use the ICC I'm told. The colors are all wrong. Most noticible are blue skies, which go more cyan.
Anyway, I see there's an ICC settings, but I can't work out what it should be.
My jpg are raw converted, and look consistent in raw converter, PS, and windows viewer.
ICC profiles
Re: ICC profiles
Could you send me the jpeg file? Do you have enabled icc in xnview?
obelisk
Re: ICC profiles
I have another problem. I have 2 monitors. Xnview lets me choose ONE icm file. That's not useful as I need to remember to change the setting whenever I use the other monitor to view pics.
