jpeg quality bug (png -> jpeg, tiff -> jpeg)
dubiousdawg
Post by dubiousdawg »
In cetain cases, the "-out jpeg" option seems to override the quality option.
When converting png -> jpeg or tiff -> jpeg with "-out jpeg" and "-q 100", nconvert will produce a low quality image with clear jpeg artifacts.
Re: jpeg quality bug (png -> jpeg, tiff -> jpeg)
Could you send comand line & sample to reproduce?
dubiousdawg
pierre,
thx for the response. after looking into it a bit further, it seems like it was still converting it into a .png without the -out jpeg flag, even though i specified the jpeg extension
however, there are still issues with the jpeg step. they are rather drastic for this particular image. see below"
original image (png)
And here are the two examples that convert produces at 90 and 100 quality
It seems that convert use subsampling 1x1,1x1,1x1 and not 2x1,1x1,1x1 as default
You can change it by using
-subsampling 2
dubiousdawg
Thanks for the response, Pierre! It was indeed the subsampling.
dubiousdawg
Pierre, is there a way to turn subsampling off completely?
dubiousdawg wrote:Pierre, is there a way to turn subsampling off completely?
no
