No copy/paste/cut ability ?
JackBauer
Post by JackBauer »
Hi all.
I have XnView version 1.98.5.
Have a question. In advance, sorry for maybe not very nice english, i'm from Russia.
The problem is: I want to copy/paste or cut/paste files this way: COPY/CUT in right part of screen and PASTE in the left side (folders tree). Exactly with pressing right mouse button on folder and select PASTE from menu.
But its no way to do this. There is no such item in the menu. You can see this on pictures.
Russian Interface, but I signed menu items in english.
I tried all settings but not found how to tune this menu. Is it not real? XnView cant do this? This sad...
I know , I can go to the destination folder (click left mouse on folder) and ctrl+v paste there, but I want exactly by clicking right mouse and paste item in menu. Could you pls add this ability in soft?
Re: No copy/paste/cut ability ?
right, to be able to paste files, you must go into the destination folder
JackBauer
Post by JackBauer »
I know :)
Do you plan to add this function (as i described, in right-click menu on folders in tree) in future versions?
Also may be to add copy/cut there, and this will be fully implemented files operations between left side ("folders tree") and right side. As in windows explorer. I think it will be best.
As now, it isn't up to the end made.
JackBauer wrote: Do you plan to add this function (as i described, in right-click menu on folders in tree) in future versions?
ok, i'll try to add it soon
JackBauer
Post by JackBauer »
nice 8) thx
Vapavite123
Post by Vapavite123 »
cool 8)
